am having an issue with a sub panel in my kitchen. I am reading 240 volts across the red and black coming from the main panel, in the panel I am reading 120 from each conductor to ground on all circuits. But on all of my double pole breakers I am reading 120 to ground but only 10 volts between line 1 and line 2... So it appears I am not getting 240 volts in the panel. The breakers don't need to be moved as everything used to work fine...
More weird info - The stove lights come on but no heat... the light in the kitchen and the outside lights only seem to work with the stove element on... Time for a new panel? help! Thanks!
