The bed in question is a Viv Rae Nadia.
I assembled the bed, put the mattress on, and stored several things on the included shelves. Any sort of movement makes a squeaking noise through some parts of the frame. What can I do to dampen this noise?
First try tightening the hardware. If you can isolate the offending joint disassemble it. Rub some candlewax on both sides then reassemble it.
