Seems obvious to me that there is no load bearing on this wall since the wall stops at this point, but would love a second opinion.
7That appears to be the case (and that's as far as I'm willing to go from my chair in Notwhereyouareville). – isherwood Sep 8 '17 at 18:07
Though your reasoning about the wall stopping isn't valid. Plenty of bearing walls terminate as such. We can't see from here what's above it all. – isherwood Sep 8 '17 at 18:08
Thanks for the response. Single story house, nothing above – What-About-Bob Sep 8 '17 at 18:09
1I agree with isherwood. There will be electrical in the wall make sure to kill the power to those when doing the demo live lines can really ruin a blade and your day. – Ed Beal Sep 8 '17 at 19:06
1Thanks for the responses. I've consulted with a local architect that thinks it can be removed. We took the sheetrock out this weekend to see what was inside, was surprised to see so many studs on the left side. – What-About-Bob Sep 11 '17 at 13:39
Your reason given (the wall stops - plenty of bearing walls do that) is not sound, but by cursory examination you appear to have a clearspan roof supported by beams that would have no reason to depend on this wall for support, so you are likely good to go. I'm guessing 1960's or early 1970's era based on the style (or when the style was popular in my area, anyway.)
As Ed notes, turn off the power first...
This wall may not bear vertical dead loads, but it could be important in resisting shearing of the house in the direction perpendicular to the ceiling beams, e.g., in case of a high wind perpendicular to the direction of the beams. Get an engineer's report.
1If it was a shear wall it would have been clad with plywood, not just sheetrock. – Craig Sep 11 '17 at 13:56
