I found a new old duct fan in a garage sale, the seller said he bought it around 10 years ago, never used it. Anyways, it was in pristine condition inside its plastic wrap but came without a box and with a tiny instruction leaflet, the only markings I found as to what it is is just stylized "CATA" written on the leaflet.
Anyways, on the backside its got 3 electrical connector marked N, L and SL. The leaflet explains(in german) that blue wire -> N, brown wire -> L and black wire -> SL.
So that's what's confusing me. There is no black wire here and while N would probably be neutral, I have no clue as to what the L or SL are. I think the L should be the hot wire (being brown) but I can't be sure.
Anybody got any insight into this?
EDIT:
I found this diagram while looking for "CATA" duct fans, it also has the N L and SL markings and I think sticking the blue wire in N and brown into both L and SL should make it work?
Still strange though, if they wanted the hot wire in SL for a switch, why also have it also permanently connected to the L? Might have something to do with the "TIMER" potentiometer on its backside..
  • L = line, SL = switched line. For the rest you should probably post a photo. – Fizz Sep 6 '17 at 20:03
  • Yeah, it may be that the fan can be configured to run for a number of minutes after the light is turned off. It's probably a bathroom fan. – Fizz Sep 6 '17 at 20:09
  • Right on! I decided to just try it and connecting L with SL made it go, after disconnecting SL the timer potentiometer controls how long it goes I think – user81993 Sep 6 '17 at 20:10
  • @Fizz yu might as well make that an answer, the posted schematic says precisely that. SL switches the lamp and also runs a rundown tm – Harper - Reinstate Monica Sep 6 '17 at 22:56
  • pardon the interruption... SL also runs a rundown timer for the fan which is why L must be always connected. – Harper - Reinstate Monica Sep 6 '17 at 22:59
L = line, SL = switched line. It may be that the fan can be configured to run for a number of minutes after the light is turned off. It's probably a bathroom fan.
