This question is common enough that it should have a place on the stack exchange - so that the best answers can easily be found.
After redoing a bath and waiting to see that everything comes together nicely, things like the following occur:
enter image description hereenter image description here
What are good solutions to alleviate this aesthetic problem?
  • The only thing I know of is mounting the assembly further back into the wall and then you end up with a different problem - screw lengths for the cover plate. Of course you might not have depth in the wall to do this. – Ken Sep 6 '17 at 8:17
Possibly this link from homedepot for the lavatory mounting ring:
https://www.homedepot.com/p/Fontaine-Glass-Vessel-Bathroom-Sink-Mounting-Ring-in-Chrome-LNF-VSMR-CP/202996136
I don't have enough rep to comment yet so feel free to move into the other answer.
| improve this answer | |
An answer at this link suggested using a lavatory mounting ring
So I realize this thread has been going on for a couple years now, but I also ran into this problem. I didn't rush in buying the Moen extension plate. I instead went over to the local Home Depot and just started walking around looking for anything that I could mount on the front or back of the mounting plate and with a matching Satin Nickel finish.
In the faucet repair aisle I found a satin nickel lavatory mounting ring that worked quite nicely. Using some adhesive caulk, I glued the included rubber washer to the mounting ring and then the ring to the mounting plate.
The end result looks better than what I would have achieved with a correct install.
  • This solution looks like it covers up the original cover plate mounting screws. This will necessitate breaking out the lavatory mounting ring if the plate ever needs to be removed for repairs. – Michael Karas Sep 6 '17 at 8:58
  • What's with that URL being just an IP address? Where does it go? Mighty suspicious. – Brad Apr 2 '18 at 18:03
  • @Brad not sure. I simply quoted a relevant answer. – Ulad Kasach Apr 2 '18 at 18:42
  • Please give yourself a check-mark for this answer. That will help others to know it's been resolved and will keep the system from bouncing it to the top of the list every now and then. – FreeMan Aug 20 at 15:57
