The water coming in from the well is supplied by thick rubber type pipe cut and angled with metal bands. There is no cut off valve to the water holding tank.
I need to replace the pressure gauge (leaking from bototm). Well is 250ft deep. I understand that I can turn off electric to the well and should cut off the water supply. There is no cut off for the water coming in from the well.
I believe I need to cut off electric to well, release pressure (can open a faucet), quickly put on the new pressure gauge, turn electric back on and turn on water. I talked to someone who said the little amount of water leaking out of the 1/4 inch hole would be insignificant, the water would have to drain back to the pump before I have a problem.
I would like any comment on installing the pressure gauge. Can anyone comment on how to install a cut off valve from the pump coming from the wall to the holding tank. The metal clamps are looking old and there are about four elbowed sections from the wall (well into house) to the holding tank. If I cut off the electric and disconnect the hose to the holding tank and the water drains back to the pump, how do I know it did that and what are the steps to get the water back up the tube
At some point I want to replace the hole unit, don't know the tech terms, but the water release valve handle is gone and the "gray box" that trips the pressure gauge to work all need to be replaced. I don't want to try that until I have enough money to call a plumber in case my attempt goes wrong.
