My house was built in the 70s so most of my outlets are on a switch in which the bottom is always hot and the tops are controlled by the switch.
I'm installing recessed lighting and I'm going to use the switch the outlets are on for the lights. While doing that I"m going to install new outlets throughout the room and I want them to be wired hot all the time now.
The red wire in the picture is the switch wire, I have tested it via meter to confirm. Both outlets are wired a little different with one have 3 neutrals and the other only having 2 so I'm a confused on how to wire the new outlets in leaving them hot on top and bottom.
PS: the outlet with 3 neutrals is jumpered for power
