I am replacing a shower faucet. The previous install soldered the copper to the shower valve but I am considering using threaded copper in case I ever need to replace it. What are the pros and cons of each type of install?enter image description here
    When soldering the new valve make sure you disassemble the new valve so you don't ruin the internals from the heat used to solder. – d.george Sep 1 '17 at 20:27
In all my years, threaded or soldered, I've never replaced a valve with the same valve, and definitely not with the threaded connections. If you think about the logistics of unthreading a shower valve to reuse the connections, you'll see what I mean.
I've come to the conclusion that the threads are for convenience of installation, not re-use.
    And to really make it replaceable he'd have to include unions in the connecting pipes, which would complicate things, and potential leak points. – Mark Sep 1 '17 at 16:25
