Cemensted bluestone border in my garden- no cement between bluestones
Closer look at the cement the bluestones sit in
I need to move this wall, but I want to reuse the bluestone for the new wall. So they need to stay whole. Luckily, there isn't any cement between the bluestones- they're just sitting in it. Has anyone tried to do this before? What tools did you use? Would love some guidance. Thank you!
  • Try to wiggle them sideways, to see if they budge at all. – ajeh Aug 30 '17 at 14:53
They don't seem to be laid too deep into the ground: excavate the soil behind one of them and try to crank it up from behind with a bar. If it is feeling pretty solid you may have to break that few inches of concrete sitting in front of them with a sledge to loosen them.
Start from a corner or an end stone if you don't want to dig whole lot of soil.
If you can't move them this way you may have to use a jackhammer to open some space around them but I doubt it would come to that.
    A sharp impact At a slightly up angle will probably quickly pop them loose, use a 2×4 scrap to protect from chipping. – Ed Beal Aug 30 '17 at 19:05
