I need help connecting a new 'C' wire for a Honeywell RTH6500WF thermostat.
Current Wiring Diagram As you can see the heating is an old boilder with a simple pump to circulate the hot water to the baseboard radiators.
The A/C has 3 connectors to it. A/C Schematic
This is the circuit board in the Blower AC connectors
This is the current thermostat current thermostat
I know I need to run a new wire for the additional wire but WHERE do I terminate the 'C' wire to on the thermostat? on the C terminal inside the A/C blower?
That wire runs to the compressor outside and then to the Y terminal of my current thermostat. Do I just need a new transformer? and how would I create the circuit on that.
Any help would be greatly appreciated.
Thank you.
  • Did you ever get this resolved? If so, please give a check-mark to the answer or write up your own answer explaining what you did to get it fixed and give yourself a check mark. That will help others with this kind of problem know that this has a resolution and is a good place to look for their answer. – FreeMan Aug 13 '20 at 11:25
  • 4
    I’m voting to close this question because it's abandoned – FreeMan Dec 11 '20 at 13:10
You want the C terminal in the air handler, yes
The terminal you're looking for is indeed the air handler's C terminal -- it's on the fan-delay board (in the back left, from the viewpoint of the picture you've posted). You'll want to tap the connection it's making to the blue wire using a "piggyback" tab terminal or by cutting and splicing into the blue wire connected to it with a wirenut.
