What is the simplest (easiest) method to properly secure the light fixture to a ceiling? Fortunately, the electric box is already in place. I believe the ceiling is drywall
  • Leave as much wire on those ballasts as possible, and sell em on ebay. You really don't need the ballast in the fixture and it will reduce weight a lot. Aug 28 '17 at 6:29
Toggle bolts. Put them in the drywall on either end. There's no chance it will pull out.
Let me expand on this by telling you a true story. I bought a house that had been reposessed by the bank. I can only assume the previous owners ransacked the place (even the fireplace mantle had been removed) and the bank had hired a contractor to come in and replace all the light fixtures. So he put a new fluorescent light (not dissimilar to yours) up in the kitchen.
With screw-in drywall anchors (insert duhn-duhn-duhnnn here).
This is what my wife walked into one morning not long after we moved in.
The screw-in anchors are rated for the weight, but not the parallel downward force (they're designed for perpendicular force). So I promptly went to the local big-box and bought some toggle bolts. Since I now had two brand-new holes, I only needed to slightly enlarge them to get the toggles through. That fixture hasn't moved since.
The toggles are your best bet because they
  1. Distribute the weight of the anchor across a wider area
  2. Would require the complete destruction of the drywall to pull out
Even the smallest toggles are rated far more than your fixture weight (a single 2" toggle is typically rated for 50-70lbs).
So what size do you need? Any size toggle will do, just be sure to check the size of the head. It should cover the hole on your fixture easily, but you might need a washer if the holes are large enough.
  • are you thinking 2 toggle bolts- one at each end of the fixture? Any suggestion on the size of the toggle bolts?
    – gatorback
    Aug 28 '17 at 11:33
  • Expanded my answer
    – Machavity
    Aug 28 '17 at 12:33
I'd try for mounting into a joist. There's one joist that the box is mounted to, so might luck out and have one very close to where you want the lights and be able to put an eye screw into some wood. Otherwise, nothing wrong with toggle bolts or other similar drywall anchors that spread the weight over a small area.
  • I like the idea of fixing the fixture into a joist. I need to mount the fixture flush with ceiling: should I do this with a drywall screw and not an eye screw?
    – gatorback
    Aug 28 '17 at 11:39
  • Any kind of wood screw would suffice. The real question here is do you want to mount it parallel to the joist? If not, be prepared to drill through the fixture to make your own holes where the joists are. That's why I didn't suggest this method (and why you don't often see it done)
    – Machavity
    Aug 28 '17 at 12:37
