I have a drain pipe for a shower. I need to attach a new pvc drain to it for a kerdi shower base. How can I tell if this is cast iron or galvanized, or something else? I'm assuming I will need to cut off that flange on top prior to doing anything.
For the record, house was built in 1956 in Hampton, Virginia. Main stack is cast iron, also lots of galvanized for other drains.
