A fan plugged into a GFCI works fine. The same fan does not work when plugged into a two pronged outlet. This fan will work when plugged into a surge protector that is plugged into the same two pronged outlet.
Where is my problem?
Sign up to join this communityA fan plugged into a GFCI works fine. The same fan does not work when plugged into a two pronged outlet. This fan will work when plugged into a surge protector that is plugged into the same two pronged outlet.
What your are saying is that you have a broken neutral and its shorting across the ground. That's why it won't work unless you have a path through the ground prong. This is potentially a dangerous situation. So get rid of the fan or have it repaired, but whatever you decide. Don't use this fan in this condition.
