I have a clawfoot tub faucet where the "stem" that leads to the shower part is angled at less than 90 degrees because back of the tub is angled greater than 90 degrees from the floor. Most of the replacement faucets I have found online have a 90 degree angle for the "stem", but for some I see that the angle is acute -- unfortunately nothing from the respective descriptions/specifications seems to distinguish a 90 degree on from an acute angled one.
- What is the name of the thing I'm calling a "stem" and/or what term(s) can I use to find a replacement that is so angled?
- Is the difference implicit in the classifications "cast iron only" and "acrylic only"?
I wasn't able to get a great angle (no pun intended) on the picture, but the "stem" is the part pointing down in this picture, looking almost like a spigot itself but for the threads around the opening. I've tried to highlight it with a red line.
UPDATE
I have still been unable to find a replacement. Sign of the Crab says they have never seen anything like it. It appears to be an Elizabethan Classics model, which afaict is a Home Depot exclusive brand. Home Depot says they know nothing about it. Trips to the top plumbing/building supply shops and salvage yards have left me no closer to finding a replacement.
Luckily I happened upon a catalog that had tons of pictures of diverter valves and identified the Kingston Brass model that appears to be the one that failed on this unit, so I'm just going to replace that and hope nothing else happens to the faucet.
