I want to install a smart dimmer switch in a 3 switch box (which requires neutral). However the one switch I need to replace is one of the simple toggle switches with 2 black wires connected inside the switch. The other 2 switches in the box have the neutral connections. The whole box is on the same circuit. Is it still possible to install this dimmer switch in this box?
    Can you post a photo of the inside of the box? – mmathis Aug 21 '17 at 15:22
  • Yes I will try to post a photo tonight. – D. Rosko Aug 23 '17 at 13:37
