The chimney on my house used to be one of those old brick ones that goes all the way down to a fireplace on the ground floor. The previous owner of my house removed the fireplace and almost all of the interior part of the chimney. The only parts left are the actual chimney on the roof, with a large, partially removed part dangling under it in the attic. This has proved way to heavy for the roof to support, so I initially wanted to remove it but the brickwork is in such a bad condition that I'm afraid hacking away at it would cause the whole thing to collapse, damaging either my attic floor, the wall, the roof, and possibly hurting people outside. Also removing the chimney would leave me with a hole in my roof that I am currently unable to repair.
I'm now thinking of rebuilding part of the chimney on a strong surface that can carry the load.
Here's a diagram of the current situation: enter image description here
There are two sturdy beams supporting the roof near the partially demolished chimney. I was thinking of bolting two perpendicular support beams onto them, with a layer of concrete forming plywood resting on top of them, below the chimney. I figured I could then build up a brick support that the chimney could then rest upon, distributing the weight through the support onto the roof beams, like so:
Is this a sound strategy, or am I likely to run into trouble?
  • I think your idea is sound in principal. I have a 1900's cottage which was originally built with a brick chimney above the kitchen for the old coal/wood stove. The bricks between the ceiling and the roof are still there supported by steel angle bars attached to the roof trusses. In my case the brickwork no longer penetrates the roof (and the hole in the ceiling now has an AC vent, with the ductwork running up through the truncated brick chimney).
    – brhans
    Commented Aug 21, 2017 at 13:38
  • Masonry chimneys are generally required to be self-supporting from the footings up. Adding the weight (of a partial demolition) to the existing truss or "sturdy beams", without benefit of an engineered solution by a professional, might be "a bad idea".
    – Upnorth
    Commented Aug 22, 2017 at 3:11
I would remove the remaining chimney. Having a massive chunk of heavy brick and mortar suspended from the upper part of the structure is not something I would want hanging over my head.
If you live in an area where there is any chance of an earthquake would put more than triple concerns and impetus to get it removed.
You do have real concern that the thing could come crashing down if you start trying to remove it so you would really need to devise some decent support under the thing to prevent it from crashing. Such support can be temporary. After proper support removal should be done from the top down a brick or two at a time.
I removed part of an old chimney this way and found it was easy to dismantle because the thing was originally made with sand/lime/horse hair for the mortar. It was a simple process of just unstacking the bricks.
  • That's why I want to support it from below, so it wouldn't be suspended from the upper part of the structure. And I can't remove the chimney, because that would leave me with a hole in my roof. Fixing that would be an even bigger expense.
    – Bas
    Commented Aug 21, 2017 at 20:34
  • I do agree with Michael though, technically removal is the 'correct' way to deal with a 'hanging' chimney. Don't forget the bricks might be worth a £1 each (in the UK) if they are desirable ones locally. A half decent roofer would make quick work of a chimney hole in my opinion, depending on the condition of the roof. Old roofs are more prone to damage during the process. If the roof has a new-ish covering, the hole could be repaired in a day.
    – handyman
    Commented Aug 22, 2017 at 18:25
There are brackets especially made for this situation. Gallows brackets in your favorite flavour of search engine should throw up some examples. Typically they'd sit into a partially chopped out mortar joint along with a few bolts into the sound brickwork above the ceiling level and then you'd use bricks and mortar to build the chimney back down onto the brackets if you follow me!
Hang on, I'll try and find a pic...
http://www.builderdepot.co.uk/gallow-bracket-chimney-support-50-x-50mm-1-pair.html enter image description here
We used to weld up our own using 3/8" (10mm) steel to custom fit the brick joints.
p.s. although I can see the logic of your solution (and arguably it's better than nothing) but it's not a good idea to add loads to things which are not designed for them. That method certainly would not pass any kind of official inspection (in the UK at least).
p.p.s An alternative method to support an old chimney (usually if the house is undergoing a 'gutting' or big refurb, is to slide an RSJ (beam) (through a small hole formed in the roof) across the house and onto the outer walls. But since you're not into repairing the roof, it's not applicable in this case.
