I have a Carrier AC Air Handler Model #FC4DNF060. The filter access panel is blocked as shown in the photo (at bottom of unit). Has anyone had a similar situation or advice on how I might be able to access in order to change the filter? Thank you.
1 Answer
Are you sure there is a filter there? Is there a return-air vent somewhere else in the house/office? The situation you show is common, but typically the filter has been relocated somewhere else in the return-air ductwork system.
