Do I need to buy tools to be able to change the tank pressure gauge?
    probably just a large enough crescent wrench. If you post a photo that would help. – Kokako Aug 8 '17 at 5:02
  • A lot of smaller pressure gauges that screw into a pipe thread use an open end wrench turn them. The wrench size is usually 7/16", 1/2", 9/16", or as Kokako wrote a crescent wrench of the appropriate size. – d.george Aug 8 '17 at 9:19
Little bit of teflon tape for the threads of the new gauge, a bath towel to sop up the water, and a pair of channel locks.
Don't forget to turn off your hot water heater, and somehow relieve the pressure from the gauge first.
    I would give a + for the Teflon tape but the channel locks tear up the brass most gauges are made of If your answer had a crescent or open end wrench instead of channel locks I would up vote. – Ed Beal Aug 8 '17 at 13:15
  • Ya, I guess I should add that, as Ed said, this is a brass fitting. I strongly discourage new plumbers using a wrench that could produce too much torque, as fine threaded brass will strip easily. That's why I prefer to use channel locks. A simple quarter to half turn past snug is all that is required, but not knowing the strengrh of the plumber, I try not to suggest that. Me being 6'2", 230lb, my idea of snug may be different from, say, a keyboarder's idea of snug. Channel locks should produce about the right torque. – NPM Aug 8 '17 at 13:52
