I poured concrete footings for my deck. I put the galvanized post base and the 4x4 post on it. Now I need to raise the ground/dirt level as water puddles there. But if I raise the ground it will cover the footing, post base and a few inches of the post. I'm concerned the dirt will decay the post. Can someone recommend a solution?
I was thinking of wrapping the post somehow or maybe cut the post and pour more concrete over the existing footing but afraid it will not hold up.
I already have a deck. It's a pool deck about 8x20 attached to another deck that is 20x25 which is attached to the house. The pool deck has 9 footings, enough that it can be freestanding but I attached it to the existing deck. I'd need to raise 5 of the nine footings about 4-6 inches. They are the footing near the pool not the rear ones near where deck is attached to other deck.
I can leave the post base which is bolted into the footing and add a few rebar pieces, put a form around and pour concrete with bonding adhesive http://www.homedepot.com/p/SikaLatex-1-Gal-Concrete-Bonding-Adhesive-and-Acrylic-Fortifier-187782/202521398. Sound reasonable? Would I just drill a few holes for the rebar pieces, maybe 4-6 inches deep? Should the holes be wider than rebar to get some fresh concrete around them?
