I'm trying to fix a repair gone awry. I noticed some scratches on my stainless steel range of unknown origin. Things like cookware never touch that part of the stove, and I never use abrasive cleaners on it, but I digress. I want them gone.
Did some research and most DIY guides and products say to apply a mild abrasive (scotch brite is common) with the grain until it buffs out. Bob Vila here said to use a microfiber cloth with barkeepers friend, which I had.
I followed his guide but (to my shock) it made it far worse! Here's the after. You can see the original scratches going up and down across the grain:
Yikes! What happened? What can I do?
