I have two devices that started to work constantly. That is I can't turn them off. They just run all the time. The switches don't do anything.
The two devices are the the ventilator and air-exchanger in the bathroom:
And there are two twiches that control them (respectively):
Now to the amazing part.
When you switch off the circuit break for the ventilator in the ceiling (the circuit break for the on/off switch), then the ventilator stop running but the air-exchanger still continues to run.
When you turn off the circuit break for the air-exchanger, the air exchanger stops running and the ventilator in the bathroom is now controllable with the on/off switch.
So my conclusion is that the controller for the air-exchanger is broken. And that the air-exchanger is hooked up to the bathroom-fan to control it too.
What bothers me is that why the fan stops when I turn off the break for the on/off switch? I mean if we agree that the air-exchanger has control over the fan too, why disconnecting the on/off switch stops the ventilator?
When the circuit-break for the air-exchanger is off, the ventilator is controller by the simple on/off switch.
| CB air-ex | CB vent | Swch Vent  || Vent  | Air-ex |
| ON        | ON      | ON         || ON    | ON     |
| ON        | ON      | OFF        || ON    | ON     |
That's ^ obvious. As I said the devices run constantly. The "switch" for the air-ex never does anything at all. It's not even included in the table.
| OFF       | ON      | ON         || ON    | OFF    |
| OFF       | ON      | OFF        || OFF   | OFF    |
When the CB air-ex is off, the control comes back to the on/off switch. So now you think that the "priority" controls is the air-exchange. Okay. See this:
| ON        | OFF     | ON         || OFF   | ON     |
| ON        | OFF     | OFF        || OFF   | ON     |
If you turn off the CB to the ON/OFF switch, the ventilator is off.
So why, when the CB vent is off the vent is off, but when the on/off switch is off, the vent is on?
Thanks kindly in advance for your thoughts and comments.
P.S. This started after the house got hit by lightening.
  • Before the house was struck by lightning, did the ventilator and air-exchanger operate completely independently from each other, or was there some interaction between their controls? – A. I. Breveleri Aug 5 '17 at 3:37
Turn off the breaker for the 3 switches and remove the cover and see if the wiring is burnt. The switch is likely shorted in the on position so only cutting power at the breaker will de-energize the circuit. And since switches are controlling the wrong things but in the same switch box there is likely wiring fused together somewhere. Follow your nose
  • The question is: why cutting the break for the on/off switch stops the fan when there is also control coming from the air-exchanger? At the same time, putting the on/off switch to off has no effect when the air-exchanger is running. That's what is bothering me. – Jenia Ivanov Aug 4 '17 at 20:42
  • I mean, I agree. Ofcourse something got fused together. But I want to understand why the on/off switch doesn't affect the ventilator but switching off the break for the on off switch stops the ventilator. That's weird to me. – Jenia Ivanov Aug 4 '17 at 20:53
  • Are they wired in series? – Derek Aug 4 '17 at 20:58
  • It gets its power source before the switch. So it's always hot. Only thing I can think of at the moment – Derek Aug 4 '17 at 20:59
  • Ground before the switch is what I meant. Sorry – Derek Aug 4 '17 at 21:02
