Are Wago connectors of the type 221 and 2273 safe to use outdoors where there will be a summer/winter heat cycle of say -10 to +30 degrees Celsius?
Also how do the Wago connectors hold up against oxidation of the copper wire? in the long term?
Sign up to join this communityAre Wago connectors of the type 221 and 2273 safe to use outdoors where there will be a summer/winter heat cycle of say -10 to +30 degrees Celsius?
The Wagobox capsule junction box for those connectors is IP68 rated - waterproof to 4m. Not sure if it is UL listed or allowed in US codes though.
However, those connectors should be ok in any junction box rated for exterior use..
