Is there any easy way for me to see if something is made from regular steel or galvanized steel?
I'm having some galvanized steel bases installed at my apartment, but I want to make sure it's actual galvanized and not regular steel or steel with a coat of rustproof paint, etc.
Thanks.
Galvanised steel has a distinctive "spangled" appearance. The crystalline structure of the Zinc is visible.
Spangle
There are two main types
  • hot-dip galvanised
  • electrogalvanised (electroplated zinc)
You can often tell if something has been hot-dip galvanised. It looks like a thicker coating is present. This is better.
