I put in a new counter top and had to take off my garbage disposal to do so. When I hooked everything back up and flipped the switch nothing happened. I grabbed my wire tester and touched the wire and there was a pop and some smoke from the disposal. Now weather the switch is on or off I have constant power to the garbage disposal. Everything else that is on that breaker works just fine. What could be the problem? And how can I fix this?
9
  • What sort of "wire tester" do you have? Aug 1, 2017 at 2:00
  • Just a standard tester. Plastic end, I have used it for years.
    – Chris
    Aug 1, 2017 at 2:12
  • You mean a non-contact voltage tester? The kind that lights up and/or beeps when you hold its tip near a live wire? Aug 1, 2017 at 2:25
  • Yes a non contact voltage teste .
    – Chris
    Aug 1, 2017 at 2:49
    If both wires were hot as you suggest, and if they were on different legs, then you may have inadvertently supplied your garbage disposal with 200+ volts. That would explain the pop sound and the magic smoke. Unfortunately I think it's unlikely you'll be able to service it yourself without causing further damage and/or a hazardous piece of equipment once reinstalled. It might be time to get a new one, and double check all those wires to see which circuits they're all coming from before connecting anything to them.
    – CactusCake
    Aug 1, 2017 at 20:41
First the bad news. If smoke came from the disposer the windings are burnt and it's never going to work. Unless when you connected the power cord (the tail), it was made up incorrectly. When you "touched the wire" most likely some of the fine strands were loose and caused a "pop".
So first take the disposer out from under the sink and check the connections and determine if the power cord was installed properly (you should be able to see the burns if it's at the connection point). Then verify that you haven't burned up the windings (they should smell burnt). If there is any hint that the windings are burned return and replace the disposer.
Then check the breaker and make sure the power is on. Then use your tester to check the outlets under the sink. The outlet below the sink is usually a duplex and one side should be continually hot and the other should be on the switch above the counter by the sink. If you don't get power there start backtracking the circuit find the damaged location and of course repair the part.
If everything seems to be ok. Reinstall the disposer.
I know you probably would like to know another way to check the windings on the disposal. Unfortunately I can't recommend a way to check it safely without a workbench or a good understanding of how to check the windings with an ohmmeter. If you really want to know that you need to take it to a motor specialist or the manufacturer's recommended warranty shop.
Stay safe and good luck.
