We hired someone to clean our gutters. They came and looked and said they had to remove the (screens?) first. When they came back to do that, they left in about half an hour saying they could not remove the (screens?) as they were afraid they might damage the (roof?) trying to remove them as something was (too glued?) to something... They left and refunded all our money almost immediately...Strange..or not? Anyone know what they might've meant? They gave me a rushed explanation, with very heavy accent, while walking to their truck! They didnt even try to upsell us to entire gutter replacement like we expected!? I dont know whether to get another gutter company or full fledged roofer for a second look/advice..and I really dont want my husband up on the roof..any thoughts, thanks!
I would suggest a roofer, especially if you're unwilling to climb up there and look yourself. If you can get up there and add some pics, we might be able to help you. Otherwise, we're just guessing.– MachavityAug 1, 2017 at 1:09
I know..Im sorry, not alot of info..thought it might sound familiar to a gutter or roofer expert...something they come across once in a while..If we can get up there I'm pretty sure we will find out what they meant..and I hope its not so bad that it explains why they left in a rush lol– Leery LadyAug 1, 2017 at 1:33
Leaving in a rush could mean either that they wasted enough time on a non-paying job and were in a hurry to get to the next job, or they messed things up and wanted to run to avoid taking responsibility for it. Hopefully it's the first case. If you know exactly where they initially set up, it would be worth having someone (the next contractor?), inspect that area.– fixer1234Oct 7, 2017 at 3:39
1 Answer
Without being able to see it, I am speculating, but I used to work for a roofing and gutter company and this sounds very familiar. Please keep in mind that the company I worked with is in the Carolinas and roofing methods do vary by region. It sounds like you have asphalt shingles. There are 2 relevant things to know about asphalt shingles. (1)Along the edge of you roof where the gutters are, there should be 2 layers of shingles, the second one being called a starter course. (2)On the bottom of asphalt shingles is a bead of sealant, very much like an adhesive, that is designed to heat up when the sun hits the roof and seal to the adjacent row of shingles.
There are many different types of gutter guards (including screens) on the market. Some of the most popular guards install by sliding the upper lip between the starter course and first course of shingles. After a few years of being in the sun, the guards can get bonded to that sealant pretty good. Also singles tend to get brittle over the years and it is probably good that the gutter cleaning company left before they did any damage.
There is also one other situation that I have seen numerous times. Occasionally, I have run into situations where the guards were not installed correctly. Particularly, I have seen cases where the installer lifted up the first course of shingles and actually nailed the guards through the shingles. Most gutter cleaning outfits would run as soon as they see this. Not to fault gutter cleaning companies, they are just not outfitted to handle such a situation.
I would suggest looking for a roofing company that also does gutters. They will tend to be larger firms and are likely to offer free evaluations. I would gather data on the age and type of your roof, gutters, and guards ahead of time if possible. The reality of the situation is that cleaning your gutters is going to be more involved than the $75 guy with a truck and a ladder is going to be able to handle. The good news is that if your roof, gutters and guards are set up correctly, they should only need to be cleaned once every 5-10 years.
