A bit of a two-part question. I had a new driveway put in this week. The sides of the driveway are exposed still after the forms were removed and I wonder whether I need to rush to fill that in so rainwater doesn't seep under the driveway. It also makes me question why the contractor didn't fill that in himself.
There is only about eight inches of slope from the garage door to the street. There is an attached concrete porch so they put a slight swale at the top by the garage to help direct some of the water to one side of the driveway and I'm wondering if it might be wise to make a french drain or some such so it doesn't create a hole in the dirt on one side from water runoff. But then we're back to the original question about whether that water would work its way under the driveway. I'm really not sure this is an issue to be concerned about.
