I have the following wall I need to sand
enter image description here.
Issue is the wall is made of plaster.
  • Is there a way to sand it without spreading plaster dust all over my kitchen, please?
Thanks.
  • Is that loose paint, in the picture?
    – tahwos
    Jul 27, 2017 at 2:32
  • hi @tahwos what do you mean by loose paint, please?
    – Andy K
    Jul 27, 2017 at 4:56
  • It looks like flakes of paint, on the surface.
    – tahwos
    Jul 28, 2017 at 23:28
  • @tahwos it is flake of paints
    – Andy K
    Jul 29, 2017 at 9:03
  • Then your first course of action, would be to remove all of the loose paint, with scrapers and a stiff brush.
    – tahwos
    Jul 31, 2017 at 23:53
You can use a Drywall Vacuum sander http://amzn.to/2uWPcdB that connects to a vacuum. The vacuum will pick up the vast majority of dust that gets created.
These things use a special abrasive screen/sandpaper that allows the dust being created to pass through the screen/sandpaper and into your vacuum cleaner. This also helps prevent the abrasives from clogging due to dust.
