I have a compressor that I use for pumping my bike, and now a hole came out of nowhere in the tank. See picture. And some orange powder also came out of it.
Question
Does there exist glue or similar that can close the hole?
    Nope, one of the most fangerous things in the world is an air tank that is failing, because they often fail a lot more explosively than that. You got lucky. – Harper - Reinstate Monica Jul 26 '17 at 14:47
I highly recommend against attempting to repair a tank that handles compressed air at over 100 PSI. Failure could be impressive and catastrophic. None of the liquid repairs designed for fuel tanks or tires are in any way appropriate, and a full reconditioning is not cost-effective.
fred_dot_u is correct that the damage was caused by internal moisture. The entire tank is compromised, and the scope of the damage is likely far greater than what's indicated from the outside. The fact that the penetration is so high up seems to indicate neglect. A compressor should be drained daily after use.
Retire the compressor, or fit a new tank that's rated for the intended purpose.
If the hole appears to have been formed from the inside out, it is possible that it is caused by rusting of the metal. The orange powder may be dislodged rust, which would confirm the above supposition.
Compressors fill a tank with outside air, causing it to become warm. As the compressed air cools, water previously suspended in the air as water vapor will condense and collect on the bottom of the tank. Many larger tanks will have drain valves to allow removal of this water.
Smaller tanks frequently do not have these valves and can be drained by turning the tank in such a manner as to position the exit hose opening at the bottom. Expect a spray of water to appear when opening the air valve.
Unfortunately, if you are experiencing enough rust to create the hole you've noted, the rest of the tank, or a good portion of it is also rusted.
As an extended process, one could pour a quantity of rust treatment product into the tank, then rinse out the resulting sludge and debris and allow the rust treatment product to dry. Following that, a sealant of the type used to seal fuel tanks could be used. This would prevent additional rust from forming and very likely close the small hole you've identified.
I understand that the use of fuel tank sealant is unpleasant. In the case of a high pressure vessel, such methods are not recommended, see Isherwood's answer as reference.
All of the above also requires that you have a suitably sized opening to access the inside of the tank. Few small compressor designs will have such an opening.
It may be necessary to retire this device.
  • I agree with your concerns about pressure vessel. In the case of steel tanks, failure in this case is clearly a pinhole or similar, no catastrophic destruction. In steel, bending or holes is not as serious as an aluminum blow out! – fred_dot_u Jul 26 '17 at 17:52
  • True, but if a poor-quality patch is made, results quickly become unpredictable. – isherwood Jul 26 '17 at 18:02
