How can I fix a cast iron wood bench from rim rack from side to side?
I have tightened all screws for each slat of wood including brackets underneath to secure the wood to the iron, but I cannot sit on it as it sways.
Thanks, C.
    Can you post a picture of the bench? (just add a link to a sharing site like imgur.com and someone with enough rep will add it for you). Any solution will depend entirely on the design of the bench. – fixer1234 Jul 24 '17 at 4:15
  • repair worn fittings / material
  • make oversize holes and use oversize bolts
  • install cross-bracing
