I had a leak where my two way connector was attached to my garden hose so I tightened it up. When I turned the water on, the male end of the two way broke off inside the female end of the garden hose. I was wondering how I would go about getting it out, as I do not want to replace the hose.
  • Using a wine cork was a great suggestion. I needed a champagne cork to fit properly. Compressed the cork to fit inside the broken male thread and it easily unscrewed out of the new hose.
    – Roger
    Commented Apr 14 at 14:42
7 Answers 7
TRY a POTATO ! just cut a piece of potato and "screw" the potato into the female end-- it just might grab enough for you to unscrew the broke male threads -- it is safe on your hands and cheap to try - won't damage anything-- I have used this to get out broken light bulb parts in a socket too! GRANDPA taught me this decades ago!
I got out my socket set and found one size that fit very snuggly in the sheared male end of the hose. For me, it was 17 mm. Banged it in there a little bit to make sure it was really snug and then set my socket wrench to loosen and it actually worked! I know the post is old, but I figure it might help somebody out in the future.
Since the cost of the tool to remove the piece would possibly cost as much as a new hose, see if you could borrow a pipe reamer
or inside pipe wrench
You should try a pair of needle nosed pliers on it
  • Yes, I tried needle nose pliers, but could not get a grip on it
    – Jagerbacon
    Commented Jul 23, 2017 at 21:26
  • You may just have to get a little rough with it with a flat head screw driver and pliers, if its brass it will bend. Commented Jul 23, 2017 at 21:29
  • There is always a replacement hose end, cut off the broken end push the new end in and add the clamp. I use these all the time as horses and tractors are hard on hoses and it is cheaper to repair than replace
    Commented Jul 23, 2017 at 22:39
  • Backwards needle nose, aka caliper pliers.
    – Mazura
    Commented Apr 10, 2021 at 19:29
Cork from a wine bottle worked for me! Very nice hose that I did not want to cut for any reason. I had an orbit double connector break off inside of hose. I tried the cork, pushed it in and twisted it out. Good luck to anyone in the future with this problem.
Used the end of a small screwdriver and a bit of electrical tape wrapped around it to be a very tight fit. Turned it hard and it unscrewed and came out
I attached a hose to one end of a copper "double spigot" piece that was screwed into the outside faucet, and which snapped off just like the questioner said, when I turned the water on. I tried the tape-on-the-end-of-a- screwdriver method above, and it worked fine. Note: I first loosened the female end by turning it counterclockwise till it turned freely, then put gorilla tape around a screwdriver handle until it fit snugly against the broken piece inside. The broken male faucet piece just easily screwed out.
