I have a relatively new house (5 years old) and am thinking of hanging a large mirror over an electrical outlet. I don't have a need for the electrical outlet in that area, so I'm fine from a usage perspective, but want to know about risks. I've looked into it, and the outlet will continue to be accessible (mirror will come off easily but very rarely), so I want to know if I should:
  1. Leave the outlet fully covered with mirror (unless there are any safety issues), or
  2. Should I cap the outlet instead?
Please advise.
  • The mirror stands off enough from the wall that it doesn't get tilted out by resting on the receptacle faceplate, right? – ThreePhaseEel Jul 23 '17 at 18:27
  • You could install a recessed receptacle, but if you don't need the receptacle it would be unnecessary trouble. amazon.com/dp/B0012DKBL2/ref=asc_df_B0012DKBL25089006/… How far from the floor is the bottom of the mirror and how far is the receptacle? Is this a full length mirror? – Jim Stewart Jul 23 '17 at 18:55
    Is the mirror easily movable as part of its ordinary usage? Or will it be affixed to the wall somehow? – Harper - Reinstate Monica Jul 23 '17 at 20:38
  • @ThreePhaseEel Mirror is flush against the wall, but doesn't get titled out by the receptacle faceplate - it's likely touching the paper that covers the middle of the back of the mirror. – Darek S Aug 1 '17 at 18:37
  • @Harper mirror is affixed to the wall towards the top of the mirror - it's a full length mirror, with the bottom of the mirror about an inch off the baseboards. Bottom of the receptacle is about 6-ish inches off he top of the baseboards. – Darek S Aug 1 '17 at 18:39
You're fine just so long as the receptacles is accessible and as long as you can take the mirror down to service it as need be I don't see a problem.
|improve this answer|||||
Nope. "Affixed" is the magic word.
You can't cover any part of any junction box, receptacle included, by any installed part of the house. The farthest you can possibly push that rule is a false back on a bookshelf where you can remove the books and shelves and false back with your hands... but even then some AHJs may reject it.
Not the answer you're looking for?Browse other questions tagged or ask your own question.
