I bought a new thermostat that needs the c wire. Old thermostat wasnt using the blue c and was stuffed back in the wall. Come to find out the blue c wire is not connected to the furnace. Trying to connect the blue c wire to my furnace. As you can see all the wires are connect except the blue c which is wrapped at the bottom of the picture.
Found solution. Just connected C blue wire to the T terminal on the old furnace.
  • The other hint is the AC wires connecting to Y and T – Stavr00 Nov 21 '17 at 17:38
