An old door-threshold was fixed into concrete with screws. Decades of wear and tear resulted in the shearing of these screws. Is there a clever / simple / easy means of removing the screw remnant in the concrete and re-using the existing hole?
Update: I will need to chop the threshold because it is wide by one inch: this should enable at least one hole to align.
    Chances are slim the new threshold has identical hole locations. Have you checked? Is there any of the screw protruding? – isherwood Jul 21 '17 at 17:51
  • Unfortunately no screw protruding (great question). If it were easy enough to remove the screw remnant, the worst case is to drill holes in the aluminum threshold? – gatorback Jul 21 '17 at 18:07
    I think isherwood is saying that unless the new threshold is the exact same make and model, the holes will almost certainly be in different places, so you'll need to drill in a different location anyway. – Harper Jul 21 '17 at 18:09
  • What about drilling the old screws out? The screws in my threshold are brass. They could probably be drilled out. Not sure about steel screws. – Jim Stewart Jul 21 '17 at 20:44
Tack weld a bar onto them and use that bar to unscrew them.
Or grind them flat and forget about them.
  • I had to grind down the screws flat and drill new screw holes in the cement. Thanks for commenting – gatorback Oct 22 '17 at 20:50
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
