Any tips on painting facis boards that are in full sun for the majority of the day? I have facia boards that need to be painted about every 5 yrs or so due to peeling. Do i need to prep better? I usually use latex paint.
  • 5 years is a short life on paint if it is quality paint placed on a properly prepared surface. I have used latex for years on my last home the paint still looks good after close to 15 years all the white trim and medium to light blue, much of the home is in full sun ok in Oregon but I have seen others paint there homes 2 times since then and my opinion was they used cheap paint but I know my neighbor did prep well because I helped him.
    Jul 20 '17 at 1:17
  • From what i understand, its not cheap paint(km) i usually remove all loose chips. Very light sanding. Clean off with water hose, let dry then prime and paint. Any tips on prepping?
    – cano
    Jul 20 '17 at 1:35
  • are you using cheap primer? Does the paint have a primer base already in it? Is there an oil based paint already on the surface? Any idea what kind of wood the facia is?
    – noybman
    Jul 20 '17 at 2:55
  • No, not cheap primer(k.moore) i have always use a separate primer and paint, not sure of the type of wood. I've been in the house 20yrs, house is about 55yrs old. And i have never used oil base paint.
    – cano
    Jul 20 '17 at 3:06
  • With paint, you want the wood to be dry and warm, but not hot. How long do you let the wood dry after hosing it off? How hot is it outside when you do your painting, typically? Are you using exterior-grade paint?
    – Chris M.
    Jul 20 '17 at 13:44
