On our property there is a fairly old garage that hasn't been tended to in some time. The floor is cracked and buckling. What are possible fixes for this?
I've attached a photo. If you look closely you can see that it has heaved up sharply through the patches.enter image description here
  • 4
    Let Godzilla out of the basement. He knows that Mothra is coming to destroy you, and he only want to help! More seriously, that amount of movement indicates a problem below (possibly not radioactive movie monster related) and the fix is unlikely to be easy or cheap, and will probably involve removing the damaged concrete to resolve the issue.
    Jul 19, 2017 at 17:55
  • I'm actually not willing to rule out Mothra at this point. My assumption has always been that there isn't an easy fix, but this is well out of my wheelhouse and I am hoping someone has a clever idea.
    – CJ F
    Jul 19, 2017 at 18:05
    If you are in a freeze-thaw zone this could be responsible for your problem. Garages are usually concrete poured slab-on-grade and the footings are only required to be 12" deep. That said, I would call a reputable concrete contractor for input. They may have an economical fix for you.
    – ArchonOSX
    Jul 19, 2017 at 18:14
  • If it's well out of your wheelhouse, the clever idea is to call in a professional.
    – mmathis
    Jul 19, 2017 at 18:15
    Buckling could be tree roots. Is there a tree fairly close to the garage? The only easy way for a home owner to decide....break out a chunk and see whats under it. Compact the ground and add gravel and sand to level it, compact it some more. Then clean out the crack with a dickie (concrete saw) and widen it a bit. Once you have prepped it all, get a load of concrete delivered, or start mixing bags and filling the holes in.
    – Jeff Cates
    Jul 20, 2017 at 0:26
a) Grind concrete until it is flat, then grout the remaining cracks. You'll have an even thinner but flat floor, problem will likely re-occur.
or
b) Pour thicker new concrete over the top, with steel mesh, to make a more resilient replacement floor. Might still crack, as base is suspect.
or
c) Cut out & remove the failed floor, inspect the base to determine true cause, remove failed layers, install proper bedding, insulation layer & damp proof membrane, re-pour concrete.
