Why did polyurethane make wood feel coarse?
In reference to the above thread...
If the first suggested solution seems to work to solve the coarseness issue, i.e. "polishing" the rough areas with brown paper, would we also need to add another coat of poly after doing so?
My parter and I are debating the issue.
(Note: The poly currently on there is a triple thick varthane, which is water based. We applied one coat per the instructions on the can. My question is in regards to having to do an addition coat after polishing, when I believed the project to be finished.)
In my view, by using the brown paper we are only removing a very small amount of the poly, the extra, or rough areas, and the stained pine wood underneath is still protected and sealed. Am I correct?
