After moving day, I think the hinge of an old bedroom closet door became crooked (upper left photo). It's a metal bar that's screwed on the bottom of the door, and a small cylinder sticks out.
This cylinder is then placed in a metal bar on the floor of the closet (lower left photo), which has a hole to fit the cylinder. The door is only kept in place by one hinge at the bottom, and one at the top (connected to the roof of the closet).
I can't find a replace hinge, every hinge I find online seems to connect an XY plane with a XY plane, while this connects a XY plane with a ZX plane.
I suppose I could fix it by:
- replacing this hinge (but where to find one?)
- bend the metal bar back to a straight horizontal bar?
- implement another hinge system. This seems hard because the hinge has a slight offset from the edge of the door by 10cm/4" (right picture)
- other suggestions
Update: I've found the Dutch name: 'speun'.
