I recently noticed some soft spots in my T1-11 siding around a window. In hopes that the problem was just in the siding I started the process of removing the rotten piece. Once I removed it I found the house had no wrap and the studs around the window had been exposed to water and now appear to have been affected by rot. I am a new homeowner and can't really classify how bad the rot is, but about 1/2in (in depth) of most of the king and jack/trimmer studs are able to chipped out fairly easily from the wall sill plate to just above the bottom of the window. The tongue and groove subfloor seems to be fine and has no softness or significant discoloration. This is on the gable end of a single story house built with a truss roof (wall runs parallel to the trusses).
Since my confidence level with modifying the structure of what I assume is a load bearing wall, I tried getting a few bids. My problem comes from what they want to do. The first quote I got was to tear out the all of the studs (king, jack and cripple, maybe others) and put new ones in and this shows in the cost of the bid. A large part of this cost I think was due to the window having a Sheetrock return and needing to be redo the interior Sheetrock after removing the jack/trimmer stud. The other quote was to simply cut away the rot and splice in new studs pieces and was far less. So, my two questions are as follows:
  1. Is this likely a load bearing wall? I'd assume all exterior walls are load bearing, but with a truss roof and the wall running parallel to it, I'm not sure.
  2. If this is a load bearing wall, is it ever acceptable to splice/repair a jack/trimmer stud? I've include a picture of what I believe the "repair" quote was saying they would do with yellow being original wood, and red being new.Repaired wall
Hopefully this is an appropriate question for this StackExchange. I'm new to this home owning thing and a bit out of my depth right now! The first bid was very high while the other seemed like it might be cutting a few too many corners...
While not super critical to my questions, I've also attached a picture of the effected area in case that makes an difference to the situation: rot images (PS The gouges in the wood are from myself/contractors testing)
  • It is my understanding that this would not be a load bearing wall. My understanding is that the trusses carry all the roof load to the side walls at the ends of the trusses. My tract house built 1970 has exactly this construction, gables front (N) and back (S), truss roof, no house wrap, but fiberboard sheathing. However, mine is brick to 8' (except for W side) and W side has no exposed windows in siding. Jul 15, 2017 at 10:27
If this wall is parallel to the trusses, it is probably not load bearing. At least that would be typical.
Water infiltration
You must address the cause of the water infiltration, or this will only happen again.
You noted the lack of housewrap, and that may be contributing, but since its by the window I'd say correct window flashing is essential. Check with the window manufacturer for instructions (they are all similar but for example: Andersen). The details really count, especially how to lap one layer over another, etc.
If you can do it from the exterior, I'd also air-seal the window to the framing while you have the chance. (e.g., Canned spray foam - low expansion).
You should add housewrap (or tar paper) wherever sheathing is exposed, and if you ever re-side tie into that later.
Framing
This is a reasonable repair to do yourself. It sounds like the rotted studs are possibly still adequate. i.e., if they are solid the remaining thickness and no water has reached the interior, you might be able to just live with them as long as the wall is closed up correctly.
You could also sister new wood side-by-side with the existing which would avoid tearing out material and damaging the interior finish. The key thing is that the header is still supported by the left stud. If you sister the king stud there you might run some long structural screws (like Headloks) just to ensure the new wood will support the header.
The thing that concerns me most if you want to leave the damaged wood in place is the sill plate. If that is rotted through it isn't doing its job (transferring the load of the wall, ensuring shear transfer through the sheathing, etc.) However you could probably just cut out that rotten piece and slip a new one in. This is unlikely to damage the interior since it is probably behind trimwork. You could also leave the rotted section if its small enough, and slip in 2 or more 2x4s on the horizontal over the top of it. This might spread out the load adequately.
  • Yeah, I believe the window/trim had been leaking. The window is a replacement and was installed without any flashing. I plan to apply flashing + wrap and careful seal the window up before/after putting the siding back on. It appears that the studs above the bottom of the window have no discoloration or rot, so I believe it was coming in from the lower left corner. I'm leaning toward just sistering a new king stud in a removing the rotted wood and repairing the remaining studs to prevent any additional issues. Jul 15, 2017 at 19:53
  • (cont) The sill plate has some damage similar to the studs. The first 1/2in to 1 in or so is soft. The rest of the wood seems solid. I may end up cutting out a 12-16in piece and fitting in a new one though just to be on the safe side. Jul 15, 2017 at 19:53
