I live on the top floor of an apartment in Southern California and it doesn't have central AC. I have a portable unit (11.4 amp, 115 V, 1310 W, 60 Hz) and it keeps tripping my breaker. I don't have access to the breaker box (I think they are in the basement), so I have to call emergency maintenance to fix it (it's always tripped after hours).
My apartment manager is so terrible that I would be better off without her. I can't ever reach her in person or via phone. I leave messages and she never returns them. I submit work orders and they are never completed. The only success I've had is contacting tenant relations with the management company.
They are dragging their feet on fixing this issue and I am staying on their case because I believe that this is a safety issue. Not su much because I NEED AC, but because it shouldn't be tripping. The only thing on this circuit is the AC unit and... I really doubt that they have me on 10 amp breakers, especially given that I have a fridge.
Anyway, the reason for this back story is I want to know if there is a way to shut off the power at the outlet. Is there a device that would go between the plug of the AC unit and the outlet that could cut off the unit if it draws more than a specified amount of electricity? I really don't want to push things too far with management and make an enemy of the property manager, but I also want AC.
Also worth noting, I've plugged my 10 amp vacuum into the outlet and it hasn't shorted. I don't know if I have anything more demanding than 10 amp, other than the fridge.
