If the attic door panel has a locking machanism and the pull chain has been pulled off, is there anyway to get the door open without damaging or replacing the door?
attic door
The 3 dots on the left side are the lock, and the hole to the right of those 3 dots is where the pull chain was.
  • Please add new information to your post, not comments. – isherwood Jul 9 '17 at 15:50
  • Have you tried fashioning a wire hook to try and trigger the mechanism? – isherwood Jul 9 '17 at 15:51
Is there anyway to get the door open without damaging or replacing the door?
Yes, drill out the heads of the three carriage bolts and then replace them after you re-attach a new chain.
Good luck!
| improve this answer | |
-1
Ended up prying it really hard to open:
latch
