The place I work at has been ordering new machinery and it comes in with 2x4 frames. They are throwing the wood away! Anyhow, I can get all I want.
So my question is how much of the shed can I do using only 2x4's? I see most bases of the shed are done with 2x8's or something along that line. I will be building it off the ground with blocks as I cannot afford a concrete slab at the moment.
I would like to build more of a shop than a shed. Maybe 15x20? But my longest "free" wood is 12 ft. My current shed is a dirt floor. I could live with that if need be.
My current shed is old school. I live in the country, so no certain requirements have to be met. Anyhow, the sheds bones are old utility poles. It's in an awkward spot, so I wanted to build a newer one in a different spot. The walls are tin. No plywood on the walls. Roof is tin as well. I'm just trying to see if the wood I get at work will be enough to cover 90% of the cost. I want 20ft long, so can I build 2 ten ft walls and join them together to make 20ft? I understand that may not be proper, but it's a shed not a house.
