I've always wondered where precisely the voltage on a circuit drops from 120v down to 0v. It's "somewhere" inside of the load (a lightbulb or whatever), but doesn't exactly make sense, because if it's just "It drops to 0 when there's resistance in the circuit", well, there's resistance in the wire the entire time, and it doesn't drop in uniform fashion throughout that circuit. So I figured I'd draw 2 things.
For the theorists: A picture eliminating the typical load to hide behind as an answer.
And the equivalent for the practitioner: A picture of witnessing someone being shocked and trying to know where it's safe to touch them (if at all) to pull them off the line.
Edit: The guy getting shocked shows voltages listed, but no meter / or where the voltage is tested from. But it's implied that if you saw a hot (120v) wire from an outlet, the voltage is the difference between that wire and ground. The idea of the pictures is to help pinpoint the idea that no one is talking about where exactly the point is that the voltage steps down from 120v to 0v.
