I just had a Rheem gas hot water heater installed in my garage. They put it on the floor and said that it doesn't have to be elevated as per code. Were they full of crap?
  • What is the floor made out of? One of the reasons to raise it is to create a fire proof barrier and provide a way to guide leaked water. – ratchet freak Jul 4 '17 at 13:02
    @ratchetfreak and to prevent explosions caused by floor level vapors ahit.com/news/Garage-Water-Heaters.htm – Tyson Jul 4 '17 at 13:32
    Does the new heater carry an FVIR (Flammable Vapor Ignition Resistant) rating? – Tyson Jul 4 '17 at 14:24
According to the manufacturer's installation instructions, Rheem gas water heaters with FVIR can be installed directly on a garage floor, without the normal 18" stand. This allowance is only if local codes do not contradict:
| improve this answer | |
  • Do all Rheem water heaters carry FVIR rating? I was unable to determine that without the model number. – Tyson Jul 4 '17 at 18:03
  • I assume somebody still makes them without FVIR, as the 2016 Cal Plumbing Code still requires 18" elevation for garage installations without FVIR... – Jimmy Fix-it Jul 4 '17 at 19:38
