I have this IKEA desk which I use for my computer. It currently holds two 27" monitors.
The monitors are too low for my eyesight, so I bought this two-monitor arms to hold them up and free some space underneath.
I was reading a bit about how strong the desk is, and it looks like the desk is likely too weak for the weight to be put on one 5cm x 5cm spot on the desk, due to the wooden panel's structure:
desk panel
So I need something to distribute the load across a larger surface of the desk. Probably something that's tough enough to actually distribute the load as opposed to something weak that will bend and just pass the load on the spot.
I'm not very experienced with DIY projects, any idea what I could use?
(I'm in London, UK, if it helps)
    Does this answer your question? Fix puncture in Ikea Linmon table Jan 26, 2021 at 13:16
  • @StayOnTarget TBH, A) that is about fixing a hole after the mount has already caused damage, and B) this question is a good reference for those who stop by periodically to ask how to do exactly this thing. To me, it makes a great dupe target and isn't a dupe itself.
    Jan 26, 2021 at 14:05
  • @FreeMan It seems like there are (at least) 3 questions that are very similar. I picked the other as the dupe target because it had the most upvotes overall, but maybe there's some other way to do it. Jan 26, 2021 at 14:06
That's an edge mount. The edges of the table top will be solid wood. The honeycomb mesh is in the center. So there is no problem with clamping the mount there.
If still you don't trust it. You can use a strip of plywood or a bit of angle iron. Note that this will reduce the available depth of the clamp.
I used two 7 by 7 inch piece of wood (1 top, 1 bottom ) and this works fine
    Welcome to Home Improvement. If you'll take the tour and browse through the help center, you'll see that we normally like longer, more complete answers. However, I've got to say that, in this situation, this really does seem to cover it! Please also note that the question you answered is nearly 3 years old, so, while very appropriate, it's a bit out of date.
    Jun 29, 2020 at 11:34
