I have wallpaper close to a cupboard as you can see in the picture below.
I'm looking for a way to remove it, without removing the cupboard.
Is there a technique that can do that?
Thanks.
Update:
This is the result. Thanks!
  • Maybe you can see something in that picture but I am sure most others will agree that about all that is clear is a couple of green rectangles. Can you try for something closer and a lot more in focus? – Michael Karas Jul 2 '17 at 15:57
I would use an Exacto knife or razor knife to neatly score along the edge of the cupboards.
Then soak the wallpaper with hot water from a sponge and then use a teakettle or other source of steam to loosen the paper until you can scrape it off with a putty knife.
Good luck!
| improve this answer | |
    Hi @ArchonOSX, thanks, I was able to remove the wallpaper in a clean manner. – Andy K Jul 24 '17 at 8:15
