I just installed a dryer vent using semi-rigid aluminum duct. Approximately 7' from where the semi-rigid duct attaches to the dryer at floor level, the duct touches a black PVC drain at ceiling level. The surface to surface contact is probably less than 2 inches. Can the heat from the semi-rigid duct damage or even melt the PVC drain pipe? I suspect the heat from the dryer has dissipated sufficiently at 7' but I have no experience doing this type of work. Thanks in advance for your responses.
FYI black plastic plumbing is ABS not PVC. It shouldn't make any material difference to your question, but they have slightly different properties. – Matthew Gauthier Jun 30 '17 at 0:39
Thank you Matthew. I've learned a lot in the last 2 days and you have been part of that process. It seems that ABS is actually somewhat more heat resistant than PVC. – Stu Z. Jun 30 '17 at 14:49
The floor level vent being the damp air exhaust it will not get hot enough to melt the PVC or do any other damage unless there is a lint fire in the pipe. Cleaning the pipe once a year will keep a fire from having fuel to burn.
