I am building 12'x14' detached deck in backyard and away from the house. Frame will be of pressure treated wood sitting on gravel pad. Essentially a rectangle build of 4x6 with one 4x6 in the middle and 8 2x6 joists spaced 16" OC.
Since I have solid support under the entire frame, do I still need joist hangers or is it ok to just use nails at the angle from inside (toe-nail)?
If so, what is recommended nail size? Ideally, I would like to use nail gun to quickly attach those joists.
You don't need joist hangers. Joist hangers are for use in spots where you're unable to put the nails directly through the frame into the joist already.
I built a shed with much the same construction, only my base frame sits on 2 6xx treated railroad ties embedded in the gravel bed, and I haven't had any problems.
I ended up using joist hangers with recommended #9 screws. That was pretty easy and gave me extra benefit of proper joist alignment so I didn't have to hold them in place.
