I want to run internet from my main house to garage located few meters away. I plan to use fiber instead of cat5 to avoid reported problems of blowing out network switches.
I could have made a trench and placed fiber inside a conduit, however any shortest path from my house to garage (from attached garage where I plan to keep all my network equipment) is filled with concrete. I would need to break concrete to dig a trench.
Instead of digging the trench, could I pass fiber from under the roof of my house? The same way the electrical cable is passed right now.
Yes, absolutely.
The fiber you'll want for this job is "Drop" fiber - it's made to resemble (and work with the hardware for) telephone "drop" wire - and it's relatively inexpensive while being quite robust.
While we tend to knee-jerk away from aerial fiber because it's more exposed to damage, this is a perfectly viable solution.
However, for most home applications at this time, it's going to be much cheaper/easier and adequately effective (not really as fast as fiber, but probably faster than your internet feed unless you have gigabit fiber to your house) to use a 5 GHz "ac" "Point to Point" radio link between the buildings.
  • I agree with the alternative suggestion to go wireless. I've bee reading up on the new wifi "mesh" networks, and they almost seem like the holy grail of home networking.
    Jun 26, 2017 at 14:12
  • 4
    Honestly, as a network guy who does a lot of wireless, the holy grail is a lot of wires in the house and fibers between buildings. Among other things, they make the WiFi you do need to run for end-use devices that don't have a plug faster and more reliable. But a good mesh implementation can be a moderately blessed grail that will get the job done good enough, with much lower barrier$ to entry. Wires/fibers still beat the snot out of wireless for moving data efficiently, particularly with walls in the way. ;^)
    Jun 26, 2017 at 16:18
