I haven't been under my kitchen sink in a while but recently went down there and found some dark oily liquid puddling directly under the drain pipe.
It was still wet and had the consistency of WD-40.
I turned the faucet on and there is no water leaking. And I have a SmartThings water leak sensor down there and that never tripped, so there was definitely no water leaks.
There wasn't that much of it, and I couldn't see where exactly it came from.
Should I be concerned, and should I do anything here? Wrap some duct tape around the pipe and call it a day?
