This question is an exact duplicate of:
I'm planning to put a window air conditioner in an apartment awning window. The window part that swings open cannot be removed so,the exhaust from the air conditioner would be blowing against the window. Would the exhaust be very hot and,if so could it cause damage to the window parts? Any suggestions?
marked as duplicate by isherwood, ThreePhaseEel, Tester101 Jun 28 '17 at 12:32
This question was marked as an exact duplicate of an existing question.
  • the thermal cutout of the AC will trigger before the window will melt. – ratchet freak Jun 21 '17 at 14:45
  • If you are restricting the air flow from the rear of the A/C unit then you can't install a window A/C in that window. You need to find another solution. – d.george Jun 22 '17 at 9:37
